Aktuelle Zeit: Mi 21. Jan 2026, 15:54
 Betreff des Beitrags: skill hilfe
BeitragVerfasst: Do 17. Apr 2008, 20:56
das folgende ist ein Guide von Jaradis aus dem crafterforum:
zum original gehts hier: http://www.vanguardcrafters.com/forum/s ... hp?t=24972
[Guide] Managing Your Stats by Jaradis
Attributes:
Until you are more comfortable with how things work, try to keep your Attributes (PS, Reasoning, etc) at (levelx10)+1 or better, with emphasis on the one you are using heavily at the time. This would mean get Reasoning to (levelx10)+1 first then Finesse from level 1 to ~23, from 24-40 get Finesse up first then Reasoning, 41+ Ingenuity first. Keep them all (levelx10)+1 if you can, just if you can't put points in those suggested above first then bring up all the others.
Quality and You
For most people starting off, high B grade on Moderate WO's will be "average" and you can still level very quickly at that rate. A's are going to be out of reach for most on Moderates until your 20's unless you have very good gear, which most won't. At 25 when you can get some valueable actions (Tool 1 Action 6, Utility 1 Action 6) as well as Ahgram/NT jewelry, getting 100% A's on moderates will not happen for a lot of people. Don't worry. Just get what quality you can without losing the WO. Getting a moderate B or even C is better than failing trying to get A and getting no xp.
Raw skills (no gear):
Level 1 - 7 Station, 7 Utilities, 10 Tools, Actions Gained: Tool 1 Action 2: Low Progress, Low Quality, 100AP
Level 2 - 16 Station, 16 Utilities, 16 Tools, Actions Gained:
Level 3 - 30 Station, 21 Utilities, 21 Tools, Actions Gained: 30 - Station 1 Action 2: High Progress, 100AP
Level 4 - 31 Station, 33 Utilities, 32 Tools, Actions Gained: 30 - Tool 1 Action 3: Moderate Progress, Low Quality, 125AP
Level 5 - 35 Station, 50 Utilities, 35 Tools, Actions Gained:
Level 6 - 42 Station, 60 Utilities, 42 Tools, Actions Gained:
Level 7 - 49 Station, 70 Utilities, 49 Tools, Actions Gained: 70 - Utility 1 Action 3: Very High Progress, 125AP
Level 8 - 56 Station, 80 Utilities, 56 Tools, Actions Gained:
Level 9 - 63 Station, 90 Utilities, 63 Tools, Actions Gained:
Level 10 - 70 Station, 100 Utilities, 70 Tools, Actions Gained:
Note: Up till level 10, you can move station/tools around as you need based on gear. Gear isn't easy to get for 1-10 sometimes and I've recently found that there are a few high +station items you can get pretty easy (Artist's Smock). So you can boost Tools more if you need, or vice versa.
Level 11 - 77 Station, 110 Utilities, 77 Tools, Actions Gained: 110 - Utility 1 Action 4: Moderate Progress, Very Low Quality, 100AP
Level 12 - 80 Station, 120 Utilities, 88 Tools, Actions Gained: 80 - Station 1 Action 3: Low Progress, 50AP
Level 13 - 80 Station, 125 Utilities, 107 Tools, Actions Gained: 125 - Utility Complication Remedy Set 2
Level 14 - 80 Station, 131 Utilities, 125 Tools, Actions Gained: 120 - Tool 1 Action 4: Low Progress, Moderate Quality, 125AP, 125 - Tool Complication Remedy Set 2
Level 15 - 80 Station, 150 Utilities, 130 Tools, Actions Gained:
Level 16 - 80 Station, 160 Utilities, 144 Tools, Actions Gained: 160 - Utility 1 Action 5: High Progress, Low Quality, 3x utility item, 150AP
Level 17 - 80 Station, 160 Utilities, 168 Tools, Actions Gained:
Level 18 - 102 Station, 160 Utilities, 170 Tools, Actions Gained: 170 - Tool 1 Action 5: High Progress, Low Quality, 150AP
Level 19 - 125 Station, 160 Utilities, 171 Tools, Actions Gained: 125 - Station Complication Remedy Set 2
Level 20 - 130 Station, 160 Utilities, 190 Tools, Actions Gained: 130 - Station 1 Action 4: Very High Progress, 125AP
Level 21 - 130 Station, 164 Utilities, 210 Tools, Actions Gained:
Level 22 - 130 Station, 178 Utilities, 220 Tools, Actions Gained:
Level 23 - 130 Station, 192 Utilities, 230 Tools, Actions Gained: 230 - Tool 1 Action 6: Low Progress, High Quality, 150AP
Level 24 - 130 Station, 206 Utilities, 240 Tools, Actions Gained:
Level 25 - 130 Station, 220 Utilities, 250 Tools, Actions Gained: 250 - Tool Complication Remedy Set 3
Level 26 - 130 Station, 244 Utilities, 250 Tools, Actions Gained:
Level 27 - 130 Station, 250 Utilities, 268 Tools, Actions Gained: 250 - Utility Complication Remedy Set 3
Level 28 - 152 Station, 250 Utilities, 270 Tools, Actions Gained: 270 - Tool 2 Action 3: High Progress, Low Quality Loss, 50AP
Level 29 - 176 Station, 250 Utilities, 270 Tools, Actions Gained:
Level 30 - 200 Station, 250 Utilities, 270 Tools, Actions Gained: 180 - Station 1 Action 5: Low Progress, Very Low Quality, 75AP; 190 - Finisher: "Quality Loss: Low" 50AP
Level 31 - 224 Station, 250 Utilities, 270 Tools, Actions Gained:
Level 32 - 248 Station, 250 Utilities, 270 Tools, Actions Gained:
Level 33 - 272 Station, 250 Utilities, 270 Tools, Actions Gained: 250 - Station 1 Action 6: Moderate Progress, Moderate Quality, 150AP
Level 34 - 290 Station, 256 Utilities, 270 Tools, Actions Gained: 290 - Finisher: "Quality Bonus: Low" 150AP
Level 35 - 290 Station, 280 Utilities, 270 Tools, Actions Gained:
Level 36 - 290 Station, 304 Utilities, 270 Tools, Actions Gained:
Level 37 - 290 Station, 328 Utilities, 270 Tools, Actions Gained:
Level 38 - 290 Station, 352 Utilities, 270 Tools, Actions Gained:
Level 39 - 290 Station, 376 Utilities, 270 Tools, Actions Gained: 375 - Utility Complication Remedy Set 4 - Quality
Level 40 - 310 Station, 380 Utilities, 270 Tools, Actions Gained: 380 - Utility 2 Action 3: High Progress, 100AP
Level 41 - 334 Station, 380 Utilities, 270 Tools, Actions Gained:
Level 42 - 358 Station, 380 Utilities, 270 Tools, Actions Gained:
Level 43 - 375 Station, 387 Utilities, 270 Tools, Actions Gained: 375 - Station Complication Remedy Set 4 - Progress
Level 44 - 376 Station, 410 Utilities, 270 Tools, Actions Gained: 410 - Utility 2 Action 4: Very High Progress, 125AP
Level 45 - 400 Station, 410 Utilities, 270 Tools, Actions Gained: 390 - Finisher: "Quality Bonus: Moderate" 175AP
Level 46 - 424 Station, 410 Utilities, 270 Tools, Actions Gained:
Level 47 - 448 Station, 410 Utilities, 270 Tools, Actions Gained: 440 - Station 2 Action 3: Moderate Progress, Very Low Quality, 100AP
Level 48 - 472 Station, 410 Utilities, 270 Tools, Actions Gained: 460 - Station 2 Action 4: Very High Progress, Low Quality Loss, 75AP
Level 49 - 490 Station, 410 Utilities, 276 Tools, Actions Gained: 480 - Station 2 Action 5: Very High Progress, Moderate Quality Loss, 50AP
Level 50 - 500 Station, 410 Utilities, 290 Tools, Actions Gained: 500 - Station 2 Action 6: Very High Progress, 125AP, 500 - Finisher: "Quality Bonus: High" 200AP
Then use gear to bring them all over level x10 or more. So you will need more +station gear early on, then shifting to +tool gear later on.
There are probably other ways you can move around your skills each level to get another ability here and there, but doing that will require you to make massive changes in gear. I know some will suggest going with a certain set up one level, then radically reducing points in one to boost another. While that might gain you an action a level or two quicker, it will require you to get possibly an entire new set of gear. My method slowly moves you along in the right direction so that you can build your gear as you go.
Unless you can get large amounts of blue/yellow crafting gear of all types and levels as you progress (from guild or friends) I'd highly recommend not doing those massive adjustments, and just sticking to a gradual increase so that you can get by with the gear you will earn as you progress.
Mitglieder in diesem Forum: 0 Mitglieder und 4 Gäste
