Aktuelle Zeit: Mo 23. Nov 2026, 08:40
 Betreff des Beitrags: Patch heute!
BeitragVerfasst: Mi 26. Mär 2008, 12:27
Quelle
Vanguard Build 2006 Patch Notes
GENERAL
- A new riftstone has come back into phase in Tanvu
- Added a point for a Tanvu Riftway to the Riftway window.
- Fixed the issue where you would be dismounted if you mouse over your flying mount item in your inventory.
- Problems with many sunken, floating, or clipping housing plots have been fixed.
CRAFTING
- Text errors in crafting specialization quests have been fixed.
WORLD POPULATION
- Coastal Graveyard - Siren's Rock has been lowered to a 2dot camp.
- Cragwing Ridge - Big Dumb Brutes: Fixed an issue with not being able to mount the griffon
- Nerkawl - Nerksawl's Rage has been slightly increased as he loses his temper with greedy adventurers.
- Quests - Forest Enchanted Gauntlets now displays the correct number of Warped Wind Essences required
- Quests - Forest Enchanted Pauldrons now shows the correct item name
- Quests - Word on the Street now offers a compass location to the main NPC.
- Quests - Above The Law: The tank reward for the quest has been slightly adjusted.
- Quests - Living Sand Samples now displays the correct number of Sand Samples required
- Quests - The Summoning: Jewel from an Ancient Relic will now be removed from your inventory if you abandon the quest.
- Quests - To The Test Site: NPC Melkov Ullosa is now refered as a male instead of female in the quest log
- Quests - Immunity Potion: The location for Mineralogist Acadd has been corrected
- Quests - Black Wyvern Down (Part 2): Quest will no longer update until you have looted Ragged Manual of Toxins
- Quests - Black Wyvern Down (Part 4): The correct NPC now spawns when clicking the censer
- Quests - Mantidae Forged Gauntlets now lists the correct amount of Warped Wind Essences required
- Quests - Bugbear Jewels: Uncut Rage Rubies now drop properly.
- Quests - Using the Weapon has been labeled as a group quest, from solo.
- Quests - By Night: This quest has been temporarily removed from the quest giver NPC.
- Quests - Griffons of a Feather Ch. 5: Creepy Cadavers: Chat's Broken Vessel works properly now.
- Tanvu - Ra'Jin Stronghold has been retuned to better fit a solo/duo dungeon.
- Tanvu - Spawn of Kojuko has been lowered in difficulty.
CODING
- Fixed a couple common client crashes that appeared in GU4.
- Fixed the sound device enumeration issue. You can now select your correct sound device
13:00 Uhr CET fahren die Server runter und 4 h später sollten sie wieder up sein. Mal schauen ob das Boot zwischen Tanvu und Tawar Galan wieder fährt...
Mitglieder in diesem Forum: 0 Mitglieder und 16 Gäste
