Aktuelle Zeit: Mi 2. Jul 2025, 15:10
 Betreff des Beitrags: SOE Marketplace mit Custom UIs aktivieren
BeitragVerfasst: Mi 8. Aug 2012, 14:46
.. hab ich im Sony-Forum schon zusammengeschrieben:
http://forums.station.sony.com/vg/posts ... 22&#695604
Index.xml:
add
<Window filename="VGUICommerceWnd.xml"/>
after the line with ... VGUITrialWnd.xml (somewhere around line 115)
SkinInfo.xml:
add
<AnimationDefinition filename="VgrdParts05.xml"/>
<AnimationDefinition filename="VgrdParts06.xml"/>
after the block that already has .. Parts02.xml to ..Parts04.xml (around line 15)
This works fine for me with the current InfoMap Advanced.
Zuletzt geändert von Visionist am Mi 8. Aug 2012, 15:28, insgesamt 1-mal geändert.
 Betreff des Beitrags: Re: SOE Marketplace mit Custom UIs aktivieren
BeitragVerfasst: Mi 8. Aug 2012, 15:24
Same goes for the DroxUI:
Index.xml:
add
after the line with ... VGUIRaidManagement.xml (somewhere around line 107)
SkinInfo.xml:
add
after the block that already has .. Parts02.xml to ..Parts04.xml (around line 22)
BeitragVerfasst: Mi 8. Aug 2012, 15:28
Also, the SC button is movable in Layout Mode..there is one spot at the very top of the bag you can grab and move it around.
