Aktuelle Zeit: Mo 19. Okt 2026, 17:51
Ein neues Thema erstellen Auf das Thema antworten  [ 13 Beiträge ]  Gehe zu Seite 1, 2  Nächste
 Betreff des Beitrags: CAG-Raid
BeitragVerfasst: Sa 27. Aug 2011, 10:42
Werd hier mal versuchen, die aktuellen Raidankündigungen reinzustellen. ;)
Heute:
Berk hat geschrieben:
Saturday August 27th. 8PM CET - APW
Targets:
- Shiver (if we have 2 tanks)
- Athris
- Dreadlord
- Senator
- Admiral
If we have only 1 tank, we skip Shiver.
Shiver is a high priority target down there, for loot. He drops Breastplate mold and Soul, for crafted items.
Also, it's a strategic fight, which is much more interesting than the simple tank/spank fights.
 Betreff des Beitrags: Re: CAG-Raid
BeitragVerfasst: So 28. Aug 2011, 17:27
Wednesday August 31th. 8PM CET - Overlands
Targets:
- Belzane the Arch Fiend
- Masuke Whitewind
- Summoner Physik
Depending on turnout and raid composition, we're going to play with Fengrot again. If we lack people, we go for known overlands instead.
We probably don't have time for much.
BeitragVerfasst: Mi 31. Aug 2011, 15:32
und der nächste:
Targets:
- Shiver
- X99
- Core
if we have time (and we succeed at Core) we end the evening doing Ores.
Preparation:
Those that have finished the quest "Cracking the C2M", please remember to bring your quest reward along. I can't remember the name exactly, but it starts with "Cracked".
Those that have attempted or done Core before and had the reward, please go to Professor Telpon and get a new "Cracked" whatever.
We need one for each attempt at Core.
Doing Core and finishing the quest line, are prerequisites for doing Kotasoth. Be there, or die :)
Sehr schade, ich kann am Samstag nicht, melde mich hiermit auch gleich mal für Freitag und Samstag ab. ;)
BeitragVerfasst: So 4. Sep 2011, 19:36
Wednesday Sept. 7th. 8PM CET - Overlands
Targets:
- Summoner Physik
- Fengrot Foulbreath
We have yet to defeat Fengrot. Expect defeat, strive for succes!
Please read up on our WIKI for strategies and also read our general rules for preparation.
BeitragVerfasst: So 4. Sep 2011, 21:33
Die Strategie für Fengrot:
* MT must have Fengrot turned away from remaining raidforce due to frontal AE.
* Two spots are chosen to off tank adds that spawn. Positions must be XXm away from each others to prevent double AE on raid members, and at least 21m away from Frengrot due to stun.
Strategy:
* He casts five regenerating enchantments on him self and they must be stripped asap. Two dedicated disenchanters is enough since it takes one disenchant per enchantment.
* Every two minutes he spawns two adds that must be off tanked (at chosen positions) and killed within the two minutes.
* Adds apply massive mana draining poison dot on target and must be tagged asap for same reason. Add damage is weak on tanks. One healer should be enough per OT.
* Upon first add spawn he stuns everyone within 20m radius and does so every following minute (synced with add spawn).
* Stun is applied as a buff on Fengrot and "pulses" two times while on and each stun lasts 4 seconds. The stun is resistable.
* He casts a severe AE dot "Disease of Krigus" that can be cured with two casts of Bard "Hue of Purity III". This dot can crit
Fight starts!
1 minute till First stun and 2 adds
Adds OT by 2 tank.
2 Tanks continue on Fengrot keeping aggro high.
Enchantment comes up every 60secs - Needs 5 dispells to remove
At the 3rd minute a new 2 adds will come and every 2mins after that.
At 75%/50%/25% - One of the OT tanks FT to prevent Aggro wipe on 2MTs
At 53% best to stop dps and wait for 2adds.
50% FT by OT
From now on its a good idea to have Disc/Monks tanking the adds so there are more Tanks to dispose of on BC/FT duty.
From 0-50% Bone crush begins every 30-40secs. This is easily seen by a swirling red/blue swords around his knees the MT must use 100% Block ability OR Have an OT FT him..
I believe he stops using Enchantment heals after 50%, He definitely stops using them by 30%.
25% is the main killer of the raid. Because OT is FT to avoid MTs dying to BC, one of the MT will probably be wiped. This can be prevented if there is a FT immunity left and hope one of the MT can block Bone crush.
20% STANCE (+20mitigation) This is recast every 20secs. So need to have it removed fast!
5% Rage! I cant remember what it is but can only guess it was +% damage or something.
Und nein, ich mag das grad nicht übersetzen. ;)
BeitragVerfasst: Mo 5. Sep 2011, 21:36
Mariwin hat geschrieben:
Na ich hoffe, ich hab das jetzt richtig verstanden. Und zwar so:
Der Main Tank muss den Mob drehen, damit der Raid vom frontalen AE verschont bleibt..
* Es werden zwei Positionen ausgesucht. Mögliche Adds werden off getankt. Dabei müssen beide Angreifer weit genug auseinander stehen/Abstand wahren, um einen doppelten AE auf den Rest des Raids zu vermeiden; wegen der Stungefahr ist eine Raid-Entfernung von mindestens 21m vom Mob zu empfehlen.
Strategy:
* Er castet 5 Renererationsverzauberungen auf sich selbst, die so schnell wie möglich disenchanted werden müssen. Dabei reichen zwei Spieler für diese Aufgabe aus, da die Verzauberungen leicht zu entfernen sind
* Alle zwei Minuten erscheinen Adds, die an den vorgegebenen Positionen getankt und bis zum nächsten Spawn getötet werden müssen.
* Des weiteren hat er ein massives Gift, das Mana entzieht. Dieses sollte gemeldet werden. Der Schaden an den Tanks ist dabei nicht besonders hoch, so dass ein Heiler pro Tank ausreichend sein sollte.
* Mit der ersten Addwelle stunt er jeden im Umkreis von 20m, was er jede Minute wiederholt.
* Der Stun ist ein Buff des Mobs, welcher 2 Minuten anhält ("tickt"). Jeder ausgehende Stun hält 4 Sekunden an, wenn ihm nicht widerstanden wird (was möglich ist).
* Er castet einen starken AE-DoT, der “Disease of Krigus heißt. Dieser kann mit Hilfe des Bardenspruchs "Hue of Purity III" entfernt werden.
Der Kampf beginnt!
Man hat eine Minute bis zum ersten Stun und der ersten Addwelle.
Adds OT by 2 tank (das muss ich ja wohl nicht übersetzen).
2 Tanks fahren damit fort, auf Fengrot einzuschlagen und halten die Aggro dabei möglichst hoch..
Alle 60 Sekunden kommt eine Verzauberung.
In der dritten Minute kommt die nächste Addwelle, was fortan alle zwei Minuten passiert.
Bei 75%/50%/25% muss einer der Off Tanks forcen.
Bei 53% sollte der Schaden eingestellt und auf die Adds gewartet werden.
Bei 50% muss der Off Tank forcen.
Nun wäre ein Disci oder Monk hilfreich, um den Tank seine Arbeit zu erleichtern (was, zum Henker, heißt BC ^^).
0-50% beginnt Bone crush alle 30-40secs. Das kann man an einer wirbelnden Schwert-Animation erkennen. Der Main Tank muss dann seine 100% Blockfähigkeit benutzen, oder der Mob muss vom Off Tank geforced werden.
"Ich glaube, dass er mit den genannten Verzauberungen bei etwa 50% aufhört, es ist aber sicher, dass er das bei 30% tut."
Bei 25% wird es kritisch, weil der Off Tank den Tod des Main Tanks per Force verhindern muss. Dies wird einfacher, wenn keine Force Immunity in diesem Moment vorhanden ist und der Main Tank Bone Crush blocken kann.
20% STANCE (+20mitigation) wird alle 20 Sekunden gezaubert und sollte schnell entfernt (gekickt) werden.
Ebenso haben wir mit Rage zu rechnen.
BeitragVerfasst: Mi 7. Sep 2011, 17:44
Saturday September 10th. 8PM CET - AP
Targets:
- I-99 Shiver
- Exalted X-99
- Core Processor
Preparation:
If you do no receive a new one, you need to petition to get one. It's a known issue and happens often.
We need one "Cracked" for each attempt at Core.
Read up on the above strategies and READ OUR RAID GUIDE
BeitragVerfasst: Fr 9. Sep 2011, 19:43
Wednesday Sept. 14th. 8PM CET - Overlands
Targets:
- Summoner Physik
Like last time, the Fengrot is last and only if we have time. We have not defeated him, it's a merely a "poke" to see what he's made of.
BeitragVerfasst: Di 13. Sep 2011, 18:29
Saturday September 17th. 8PM CET - Overland 1st attempt
We need a small break from the failures in APW, so we're attempting something new. This time it's a DPS fight.
Target(s):
- Guar
Our DPS classes have had little chance to shine lately, so let's give them some fun.
Also, we have an interest in measuring how well our allies DPS are and to identity weak spots.
We have not attempted Guar before and our strategy on him is nearly blank. Expect many attempts and if you're afraid of loosing xp, don't show up.
I expect that multiple people can and will log this fight completely. Please sound off if you're doing so. If you don't know how and what to log, don't bother.
BeitragVerfasst: Di 12. Jun 2012, 18:32
CAG plant ein greifen raid event nächsten dienstag.
-> http://www.angrygoblin.com/Calendar.aspx
die leute die dran teilnehmen wollen, sollten sich im kalendar anmelden.
so wie es bisher bei mir aussieht werde ich aber an dem dienstag nicht können, da ich mal wieder bis 21h in der uni sein werde. :wall:
